ich habe mal eine kurze Frage.
Hat jemand von Euch Infos darüber ob zur Zeit EGNOS ausgefallen ist, bzw. nicht mehr richtig funktioniert?
Wernie
EGNOS ausgefallen?
Re: EGNOS ausgefallen?
Hallo Wernie,
die aktuellen Leistungsziffern von EGNOS kannst du hier einsehen:
http://www.egnos-pro.esa.int/IMAGEtech/ ... flash.html
Eine weitere gute Infoquelle aus erster Hand findest du hier:
http://www.essp.be/
und speziell da http://asqf-gnss.com/WebPortal/Egnos/Pages/Home.page kann man auch lesen, dass PRN126 derzeit down ist:
..."PRN126
Timed at: 2/17/2009
Due to maintenance activities on EGNOS ground segment, Signal in Space from PRN 126 will be unavailable from 01/02/2009 8:00 UTC until 17/02/2009 18:00 UTC."...
Und der 126er ist derzeit in D, zumindest in Süd-D unser bestes Stück.
http://www.essp.be/
..."PRN126
Timed at: 2/17/2009
Danke für Deine Antwort!
Hallo Wernie,
gern geschehen.
Und gerade finde ich das im Postkasten:
..." OPERATIONAL INFO SOURCE: ASQF
LAST UPDATED: Tuesday, February 17, 2009
MESSAGE: SIS outage on PRN120 scheduled for 17 Feb 2009 from 11:35 to 12:55 UTC. As PRN 124 is expected to broadcast message 0/2 since 11:00 UTC, SIS will therefore be available at least from one GEO during this activity.
DISCLAIMER: The use of the EGNOS SIS is at the user's own risk. The EGNOS SIS is provided for test purposes without any warranties regarding availability, continuity, accuracy, reliability, fitness for a particular purpose or meeting the users' requirements. Until further notice, the EGNOS SIS has not been duly certified by the competent authorities and therefore may not be used for any civil aviation purposes or any other safety of life purposes where a failure in availability, continuity or accuracy of the data could cause any kind of direct or indirect damage, including body injuries or death. No advice or information, whether oral or written, express or implied, obtained by a user from the ESSP or Aena shall create any warranty. By using the EGNOS SIS, the user agrees that the ESSP, ESA or Aena shall not be liable for any direct, indirect, incidental, special or consequential damages, including but not limited to, damages for interruption of business, loss of profits, goodwill or other intangible losses, resulting from the use of, misuse of or the inability to use the EGNOS SIS."...
Vielleicht rüsten sie jetzt das EGNOS endlich für den uneingeschränkten Betrieb
Zu wünschen wäre es uns!
gern geschehen.
was ich beisteuern könnte ist
- einmal Häme: solange Geld fließt wird man nach meiner Meinung immer weiter testen-testen-testen ...
Die Einführung wird in regelmäßigen Abständen zwecks Ruhigstellung zugesagt.
- weiterhin die Feststellung, wenn die Entwicklung auch stockt, der Jurist bei der ESA ist spitze !
(Hoffentlich liest der das nicht, hoffentlich liest der das nicht ...
- dann noch einen Link
zur Performance
Habe die Grafiken selbst nur überflogen.
zur Performance
DU wieder mit deiner Häme...sag mal, liest die ESA hier mit, oder hast du in dem Laden direkte Weisungsbefugnisse...?
http://www.heise.de/newsticker/ESA-will ... ung/132663
Und ich dachte all die Jahre, die EGNOS-Kontrollstationen seien schon lange in Betrieb?!?
Im Ernst:
Das fand ich heute in der Post:
..."OPERATIONAL INFO SOURCE: ASQF
LAST UPDATED: Saturday, February 21, 2009
MESSAGE: Low risk of EGNOS SIS continuity loss from 16 Feb until 21 Feb due to GEO move activities."...
Anscheinend wird da derzeit wirklich gearbeitet, na, zumindestens wird schon mal umgeparkt.
Schaun mer mal...
dann sehn mer schon...
Im Ernst:
Schaun mer mal...
