Re: ublox neo m8t mit rtknavi
Verfasst: 09.05.2016 - 17:46
von Navigator123
Hier der Inhalt der ini-Datei:
[stream]
streamc0=1
stream0=0
format0=4
path_0_0=COM22:9600:8:n:1:off
path_0_1=
path_0_2=::x1
path_0_3=
streamc1=0
stream1=0
format1=4
path_1_0=COM23:9600:8:n:1:off
path_1_1=:@:5800/:
path_1_2=::x1
path_1_3=
streamc6=0
stream6=0
format6=0
path_6_0=
path_6_1=
path_6_2=::x1
path_6_3=
streamc2=0
stream2=0
format2=0
path_2_0=
path_2_1=
path_2_2=
path_2_3=
streamc3=0
stream3=0
format3=0
path_3_0=
path_3_1=
path_3_2=
path_3_3=
streamc4=0
stream4=0
format4=0
path_4_0=
path_4_1=
path_4_2=
path_4_3=
streamc5=0
stream5=0
format5=0
path_5_0=
path_5_1=
path_5_2=
path_5_3=
streamc7=0
stream7=0
format7=0
path_7_0=
path_7_1=
path_7_2=
path_7_3=
rcvopt1=
rcvopt2=
rcvopt3=
[serial]
cmd_0_0=!UBX CFG-GNSS 0 32 32 1 6 16 16 0 0@@!UBX CFG-GNSS 0 32 32 1 3 16 16 0 1@@!UBX CFG-MSG 2 21 0 0 0 1 0 0@@!UBX CFG-MSG 2 19 0 0 0 1 0 0@@!UBX CFG-RATE 200 1 1@@@@@@@@@@@@@@@@@@@@
cmdena_0_0=1
cmd_0_1=!UBX CFG-MSG 2 21 0 0 0 0 0 0@@!UBX CFG-MSG 2 19 0 0 0 0 0 0@@!UBX CFG-RATE 1000 1 1@@
cmdena_0_1=1
cmd_1_0=!UBX CFG-GNSS 0 32 32 1 6 16 16 0 0@@!UBX CFG-GNSS 0 32 32 1 3 16 16 0 1@@!UBX CFG-MSG 2 21 0 0 0 1 0 0@@!UBX CFG-MSG 2 19 0 0 0 1 0 0@@!UBX CFG-RATE 200 1 1@@@@@@@@@@@@@@@@@@@@
cmdena_1_0=1
cmd_1_1=!UBX CFG-MSG 2 21 0 0 0 0 0 0@@!UBX CFG-MSG 2 19 0 0 0 0 0 0@@!UBX CFG-RATE 1000 1 1@@
cmdena_1_1=1
cmd_2_0=
cmdena_2_0=0
cmd_2_1=
cmdena_2_1=0
[tcpip]
cmd_0_0=
cmdena_0_0=0
cmd_0_1=
cmdena_0_1=0
cmdena_1_0=1
cmdena_1_1=1
cmd_2_0=
cmdena_2_0=0
cmd_2_1=
cmdena_2_1=0
[prcopt]
mode=2
nf=1
elmin=0,261799387799149
snrmask_ena1=0
snrmask_ena2=0
snrmask_1_1=0
snrmask_1_2=0
snrmask_1_3=0
snrmask_1_4=0
snrmask_1_5=0
snrmask_1_6=0
snrmask_1_7=0
snrmask_1_8=0
snrmask_1_9=0
snrmask_2_1=0
snrmask_2_2=0
snrmask_2_3=0
snrmask_2_4=0
snrmask_2_5=0
snrmask_2_6=0
snrmask_2_7=0
snrmask_2_8=0
snrmask_2_9=0
snrmask_3_1=0
snrmask_3_2=0
snrmask_3_3=0
snrmask_3_4=0
snrmask_3_5=0
snrmask_3_6=0
snrmask_3_7=0
snrmask_3_8=0
snrmask_3_9=0
dynamics=0
tidecorr=0
modear=1
glomodear=0
bdsmodear=0
maxout=5
minlock=0
minfix=10
ionoopt=1
tropopt=1
ephopt=0
niter=1
eratio0=100
eratio1=100
err1=0,003
err2=0,003
err3=0
err4=1
prn0=0,0001
prn1=0,001
prn2=0,0001
prn3=10
prn4=10
sclkstab=5E-12
thresar=1
elmaskar=0
elmaskhold=0
thresslip=0,05
maxtdiff=30
maxgdop=30
maxinno=30
syncsol=0
exsats=
navsys=15
posopt1=0
posopt2=0
posopt3=0
posopt4=0
posopt5=0
baselinec=0
baseline1=0
baseline2=0
[solopt]
posf=0
times=0
timef=1
timeu=3
degf=0
sep=
outhead=0
outopt=0
datum=0
height=0
geoid=0
nmeaintv1=0
nmeaintv2=0
[setting]
debugstatus=0
debugtrace=0
rovpostype=0
refpostype=0
rovantpcv=0
refantpcv=0
rovant=
refant=
satpcvfile=
antpcvfile=
staposfile=
geoiddatafile=
dcbfile=
eopfile=
tlefile=
tlesatfile=
localdirectory=C:\Temp
svrcycle=10
timeouttime=10000
recontime=10000
nmeacycle=5000
svrbuffsize=32768
solbuffsize=1000
savedsol=100
navselect=0
sbassat=0
dgpscorr=0
sbascorr=0
nmeareq=0
intimetag=0
intimespeed=x1
intimestart=0
outtimetag=0
outappend=0
outswapinterval=
logtimetag=0
logappend=0
logswapinterval=
nmeapos1=0
nmeapos2=0
fswapmargin=30
timesys=0
soltype=0
plottype=0
plottype2=0
panelmode=0
proxyaddr=
moniport=52001
panelstack=0
rovantdel_0=0
refantdel_0=0
rovpos_0=3,9325782161665E-12
refpos_0=6378137
rovantdel_1=0
refantdel_1=0
rovpos_1=0
refpos_1=0
rovantdel_2=0
refantdel_2=0
rovpos_2=21384,6857451801
refpos_2=0
posfontname=Palatino Linotype
posfontsize=12
posfontcolor=0
posfontbold=0
posfontitalic=0
[tcpopt]
history0=
history1=
history2=
history3=
history4=
history5=
history6=
history7=
history8=
history9=
mntphist0=
mntphist1=
mntphist2=
mntphist3=
mntphist4=
mntphist5=
mntphist6=
mntphist7=
mntphist8=
mntphist9=
[mapopt]
nmappnt=0
[viewer]
color1=0
color2=16777215
fontname=Courier New
fontsize=9
[window]
width=659
height=475
splitpos=180
splitpos2=459
[navi]
ion=1.30385160446167E-08,2.23517417907715E-08,-5.96046447753906E-08,-1.19209289550781E-07,1.00352000000000E+05,1.14688000000000E+05,-1.31072000000000E+05,-4.58752000000000E+05,
utc=-9.31322574615479E-10,-7.99360577730113E-15,2.33472000000000E+05,1.89600000000000E+03,
leaps=17
eph_14=G15,17,17,0,0,1462716000,1462716000,1462710156,2.65595381338271E+07,8.10483831446618E-03,9.31386093980741E-01,1.21767553113065E-01,4.83487511446955E-01,-2.60995785149493E+00,4.98163607656699E-09,-8.04926385557716E-09,-3.90373403476320E-10,1.15000000000000E+02,5.50000000000000E+01,2.55927443504333E-06,1.29472464323044E-05,0.00000000000000E+00,-2.53319740295410E-07,5.04000000000000E+04,4.00000000000000E+00,-3.09973955154419E-04,-1.70530256582424E-12,0.00000000000000E+00,-1.07102096080780E-08,1,0,
eph_19=G20,75,75,0,0,1462183200,1462183200,1462179996,2.65609828444012E+07,4.61706414353102E-03,9.26289340057625E-01,-8.24717755776298E-01,1.36439691178508E+00,1.40037230123017E+00,5.29164898984919E-09,-8.35284792964383E-09,8.67893294096486E-11,1.18781250000000E+02,-1.83437500000000E+01,-9.27597284317017E-07,1.26305967569351E-05,-1.08033418655396E-07,-4.84287738800049E-08,1.22400000000000E+05,4.00000000000000E+00,4.09652013331652E-04,2.38742359215394E-12,0.00000000000000E+00,-8.38190317153931E-09,1,0,
eph_23=G24,41,41,0,0,1462716000,1462716000,1462710156,2.65598613747236E+07,4.39606676809490E-03,9.49550014009490E-01,1.20493931074167E+00,4.18178695164042E-01,2.60137375249275E+00,4.94306304127381E-09,-8.42427947648305E-09,3.30370904131378E-10,2.85812500000000E+02,1.46750000000000E+02,7.49900937080383E-06,4.55416738986969E-06,-5.40167093276978E-08,-6.51925802230835E-08,5.04000000000000E+04,4.00000000000000E+00,-1.67218968272209E-05,-5.68434188608080E-13,0.00000000000000E+00,2.32830643653870E-09,1,0,
eph_04=G05,6,6,0,0,1462183184,1462183184,1462179996,2.65615154347973E+07,4.57591342274100E-03,9.46434405191877E-01,-7.52329229372184E-01,4.56639529760752E-01,2.97189482348545E+00,4.83913014062275E-09,-7.99640451091614E-09,1.30362572981571E-10,1.22625000000000E+02,4.06250000000000E-01,4.09781932830811E-08,1.29360705614090E-05,-5.77419996261597E-08,-2.23517417907715E-08,1.22384000000000E+05,4.00000000000000E+00,-1.24177895486355E-04,3.06954461848363E-12,0.00000000000000E+00,-1.07102096080780E-08,1,0,
eph_12=G13,40,40,0,0,1462363200,1462363200,1462363026,2.65604271198344E+07,4.46545542217791E-03,9.71994262639677E-01,4.17369702929125E-01,2.00069207706132E+00,1.41053287440168E+00,4.53554606655608E-09,-8.14748223248108E-09,4.58233372973577E-10,2.40062500000000E+02,1.16750000000000E+02,5.97909092903137E-06,7.49342143535614E-06,1.04308128356934E-07,-8.00937414169312E-08,3.02400000000000E+05,4.00000000000000E+00,-1.54692679643631E-05,-2.61479726759717E-12,0.00000000000000E+00,-1.11758708953857E-08,1,0,
eph_11=G12,54,54,0,0,1462716000,1462716000,1462710186,2.65610000861698E+07,6.13221060484648E-03,9.90268325770614E-01,2.32806510491340E+00,7.33960847523922E-01,1.14396271276446E+00,4.14088677026941E-09,-8.26355849609481E-09,-5.01092301077107E-10,3.44500000000000E+02,-9.36250000000000E+01,-4.82238829135895E-06,2.67662107944489E-06,-1.04308128356934E-07,9.31322574615479E-08,5.04000000000000E+04,4.00000000000000E+00,3.79002653062344E-04,1.25055521493778E-12,0.00000000000000E+00,-1.25728547573090E-08,1,0,
eph_17=G18,46,46,0,0,1462276800,1462276800,1462276566,2.65604650827916E+07,1.71024762094021E-02,9.25059717913213E-01,-7.73634780605340E-01,-1.89146305875427E+00,-1.45320879291641E+00,5.22843207089648E-09,-8.24712924032179E-09,-1.01789954245884E-10,1.04500000000000E+02,-1.80000000000000E+01,-6.51925802230835E-07,1.30161643028259E-05,2.79396772384644E-07,3.40864062309265E-07,2.16000000000000E+05,4.00000000000000E+00,5.11449296027422E-04,4.20641299569979E-12,0.00000000000000E+00,-1.21071934700012E-08,1,0,
eph_18=G19,73,73,0,0,1462716000,1462716000,1462710156,2.65598094736078E+07,1.07949987286702E-02,9.73629219885066E-01,-2.86619459472665E+00,7.57410511473693E-01,1.34973957859689E+00,3.79515808356760E-09,-7.67139097279770E-09,-3.46443002170202E-11,1.42968750000000E+02,-7.95312500000000E+01,-4.07546758651733E-06,1.30236148834229E-05,-1.56462192535400E-07,-3.91155481338501E-08,5.04000000000000E+04,4.00000000000000E+00,-5.25706913322210E-04,0.00000000000000E+00,0.00000000000000E+00,-1.49011611938477E-08,1,0,
eph_09=G10,76,76,0,0,1462363200,1462363200,1462363056,2.65605250253928E+07,1.45954475738108E-03,9.59573561496191E-01,-7.46219410530848E-01,-2.73851197959323E+00,-1.11927775347397E+00,4.42411285348690E-09,-7.96426031483849E-09,-3.58586365132869E-10,1.32156250000000E+02,-5.05312500000000E+01,-2.57417559623718E-06,1.26622617244720E-05,1.67638063430786E-08,-1.86264514923096E-08,3.02400000000000E+05,4.00000000000000E+00,-1.41332857310772E-05,-9.20863385545090E-12,0.00000000000000E+00,2.32830643653870E-09,1,0,
eph_13=G14,11,11,0,0,1462276784,1462276784,1462276506,2.65637915570835E+07,8.55167605914175E-03,9.64464589638573E-01,3.81196014938394E-01,-1.96682434880307E+00,3.13518004142734E+00,4.74626912973177E-09,-8.17748348215355E-09,3.63943731145810E-10,2.43312500000000E+02,9.15312500000000E+01,4.75533306598663E-06,6.96629285812378E-06,1.22934579849243E-07,-2.23517417907715E-07,2.15984000000000E+05,4.00000000000000E+00,-1.17737799882889E-05,-2.04636307898909E-12,0.00000000000000E+00,-9.31322574615479E-09,1,0,
eph_16=G17,94,94,1,0,1462363200,1462363200,1462363026,2.65604363402498E+07,1.09486341243610E-02,9.76387500721392E-01,-2.79186867178220E+00,-1.92855299867057E+00,-2.97604108442244E+00,4.00052378073034E-09,-7.65674750569566E-09,6.55741599984011E-10,2.10125000000000E+02,6.52187500000000E+01,3.41422855854034E-06,9.13813710212708E-06,4.65661287307739E-08,-1.49011611938477E-08,3.02400000000000E+05,4.00000000000000E+00,-2.03566160053015E-04,-2.27373675443232E-13,0.00000000000000E+00,-1.07102096080780E-08,1,0,
eph_24=G25,99,99,0,0,1462716000,1462716000,1462710156,2.65612003820630E+07,5.58940006885677E-03,9.78473139139461E-01,2.27736695912070E+00,7.60824305420485E-01,6.05501809100778E-01,4.48875840337639E-09,-8.47463871700470E-09,-4.32875173845655E-10,3.56843750000000E+02,-8.23437500000000E+01,-4.14624810218811E-06,1.55158340930939E-06,-7.07805156707764E-08,1.11758708953857E-07,5.04000000000000E+04,4.00000000000000E+00,-1.67577527463436E-04,-7.04858393874019E-12,0.00000000000000E+00,5.58793544769287E-09,1,0,
eph_31=G32,7,7,0,0,1462363200,1462363200,1462363056,2.65595800673514E+07,2.94850557111204E-04,9.60235012591141E-01,2.98328686792983E-01,-2.40465316149052E+00,-2.58687109948476E+00,4.65840832711953E-09,-8.21605651744673E-09,4.18588864477811E-10,1.92343750000000E+02,1.11562500000000E+02,5.86919486522675E-06,9.62615013122559E-06,8.38190317153931E-08,-1.06170773506165E-07,3.02400000000000E+05,4.00000000000000E+00,-1.33272260427475E-06,-4.88853402202949E-12,0.00000000000000E+00,4.65661287307739E-10,1,0,
eph_104=C15,0,0,0,1,1462060814,1462060814,1462276484,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0,0,
eph_05=G06,99,99,0,0,1462716000,1462716000,1462710276,2.65604332929908E+07,4.41777869127691E-04,9.63766025774870E-01,-1.91570556724920E+00,-1.43372185512724E+00,2.73691169496924E+00,4.50697344782039E-09,-7.96747473444626E-09,7.08243786910836E-10,2.24687500000000E+02,3.83125000000000E+01,2.03587114810944E-06,8.10809433460236E-06,-7.45058059692383E-08,5.77419996261597E-08,5.04000000000000E+04,4.00000000000000E+00,1.87217723578215E-04,5.57065504835918E-12,0.00000000000000E+00,4.19095158576965E-09,1,0,
eph_01=G02,20,20,0,0,1462715984,1462715984,1462710156,2.65613148821355E+07,1.56452208757400E-02,9.42720775944313E-01,-1.95239688832143E+00,-2.12186409231641E+00,2.76810560689231E+00,4.84627329530667E-09,-7.91854412486139E-09,7.65389024382209E-10,2.05375000000000E+02,3.75312500000000E+01,1.88313424587250E-06,8.38749110698700E-06,7.63684511184692E-08,-1.22934579849243E-07,5.03840000000000E+04,4.00000000000000E+00,5.92989381402731E-04,-2.04636307898909E-12,0.00000000000000E+00,-2.00234353542328E-08,1,0,
