RTKLIB auf Android-Geräten
gto234
Re: RTKLIB auf Android-Geräten
Beitrag von gto234 » 02.06.2016 - 17:58
Hagen.Felix hat geschrieben:
gto234 hat geschrieben:... forwarding the output solution to TCP Server ...
That's the best way, IMHO ... :wink:
Yes it works pretty good!
For whom may interest the android app I used to forward the NMEA message from TCP Client to Bluetooth SPP is called "GetBlue Data Acquisition Tool" and it was the only one that could make this happen.
One more question.
Do you find better mode for kinematic the Continuous or Fix-and-Hold method?
The fix-and-hold works good but I don't know if the accuracy is good because it holds the fix with very little satellites.
In the other hand the continuous method is somehow unstable because it fixes pretty quick at start and then if the receiver loses the signal it delays a lot to fix again.
What do you think?
Beitrag von Hagen.Felix » 02.06.2016 - 20:37
gto234 hat geschrieben:... the android app I used to forward the NMEA message from TCP Client to Bluetooth SPP is called "GetBlue Data Acquisition Tool" and it was the only one that could make this happen.
Even Android is only "second choice" mobile device OS for my daily work, this was one of the first paid apps that I installed ... :mrgreen:
Developer website: http://www.tec-it.com/de/software/andro ... fault.aspx
As already quite often discussed in this forum, "Fix & Hold" isn't any good way with our L1 only receivers.
Usually the "Continuous" option should be preferred, and it could be very useful to get this additional benefit:
https://rtklibexplorer.wordpress.com/
resp.
viewtopic.php?f=4&t=3634
resp.
https://github.com/rtklibexplorer/RTKLIB/
gto234
Beitrag von gto234 » 06.06.2016 - 09:22
Thanks for the links, they are very useful.
I now understand why I see this behavior. At first it fixes very fast, then after a while it looses the fix and reverts to float and stays there. So it is a bug of rtklib.
I will try different settings suggested from the links you sent to see if I have better results.
Beitrag von Hagen.Felix » 18.07.2016 - 13:59
Hagen.Felix hat geschrieben:Dinu Berca im Arbeitseifer ... :mrgreen:
Da jetzt gerade mal wieder am Thema dran, siehe da ... :mrgreen:
https://rtklibexplorer.wordpress.com/20 ... omment-131
June 21, 2016 at 11:56 pm
Dinu says:
Hi
You can download the fresh RTKGPS+ builds of from here:
https://mega.nz/#!9wtgCKBI!tfD7neNLF2Bc ... i2H8E1ZvCY (2.4.2 P11 ARM&X86)
or from here:
https://mega.nz/#!8tkEjSJb!50lCbV0XPBP5 ... 1AGG_Nknfk (2.4.3 b12 X86 only)
Beitrag von spunky » 21.08.2016 - 10:54
ich bekomme keine Verbindung zur TCP Ausgabe von RTKGPS+ (z.B. localhost:1234), kann das jemand bestätigen?
TCP von RTKnavi vom PC zu Android geht.
auch bei der Ausgabe im allgemeinen stimmt was überhaupt nicht, da bekomme ich extreme Abweichungen innerhalb von wenigen Sekunden:
stürtzt auch regelmäßig ab und startet neu.
